Lab-PC-1200AI interval scan one channel different gains
Is it possible to perform interval scanning on a Lab-PC-1200AI and scan one channel (the same channel) at different gains ? I wish to sample the same channel at all of the available board's gains as a form of autoscaling. Or is this not possible because the board does not have a gain-channel on-board list/queue ? I'm getting error -10007 at AI Group Config when I attempt to do this.
(2,445 Views)
Steve,
The error you are getting is because you cannot scan the same channel multiple times in the same scan list. I do see why you would want to do this though. You may want to add a "start-up" routine where you have a sequence structure that acquires on a certain channel with a different gain each sequence and picks the best one. As far as adding the same channel to the same scan list with different gains, that will cause the error you are seeing.
Ross C
(2,445 Views)
