daqpad 6020E not responding to first IRQ Level
We have an application with a DAQPad-6020E with USb interface. The application was working fine. We took appart the test stand to recalibrate the instrument. Once we reconnected every instrument, we try the application again. It wouldn't run. the Labview program could not initialized the DaQpad. so we couldn't read the instruments. In Max when I try to use the test pannel for the device MAX comes back with the message:
Device not responding to first IRQ level, do you want to continue?
We didn't get this problem before. We did not run the application nor put power to the DAQPAd while the instruments where disconnected.
How do I fix the problem?
Looking at you knowledge data base it looks that it is a common pr
oblem for your hardware. Are you doing something about it? That the second time this happend for this application. The first solution was to replace the DAQPad. We cannot keep replacing the DAQPad every time we want to use the test stand
Xavier Ollat
Message 1 of 1
(2,427 Views)
