Multifunction DAQ
Load Cell Graph Questions
Hi, I'm here to ask you a question about the graph
I transformed the existing file and made two data graphs as shown in the picture below
The first graph shows a linear pattern, and the second one does not.
Why is that?
Is there a solution?
Please help me
(1,701 Views)
I don't an actual hardware but I don't see your issue using simulated device.
Btw, since both of your channels have the same settings. You could combine both of them into a single task. See Easily Synchronize and Trigger NI-DAQmx with Channel Expansion
(1,664 Views)
Thank you. I'll try it right away
(1,650 Views)
If one graph works like a video, the other graph doesn't work.
Can you tell me how? Each one will use a different sensor
(1,626 Views)
