Log an analog channel and counter period channel to hard disk simultaneously
We are in a rush, and need to log one analog channel and one counter period measurement to disk simultaneoulsy using card controlled timing and set # of samples. Should be easy, but can't figure it out. Labview 6.1 we have & DAQ 6013E we just bought.
(2,528 Views)
Greetings,
With regards to logging analog input data to file, I would suggest that you examine the examples available in the following location:
Examples >> Hardware Input and Output >> DAQ >> Analog Input >> Stream to Disk
Because you are interested in a finite number of samples, you should look at Acq N Scans to File (wdt).vi.
With regards to logging period measurement data to file, I would suggest that you examine the following example:
Examples >> Hardware Input and Output >> DAQ >> Counters >> DAQ-STC >> Measure Buffered Period (DAQ-STC).vi
This example does not log to file, but it does demonstrate how to program a buffered period measurement. You will need to add the logging functionality to this VI as demonstrated in Analog Input >> Stre
am to Disk.
Good luck with your application.
Spencer S.
(2,528 Views)
