Looking for USB DAQ for AO using external sample clock
Hi all,
I am looking for cheap solution for DAQ which allow user to set AO using external digital signal as sample clock, and I just realized that USB-6001 is not a good candidate. Would please someone point out the cheapest USB version for this task? It doesn't need high sampling rate. Thank you.
(4,498 Views)
Accepted by skuo1008
Define cheap and low sample rate. You have already been told about the 6211.
(4,491 Views)
Thanks for reply. All we need is single AO channel with external sample clock rated less than 100Hz, and I was wondering if there is one less than $500.
(4,482 Views)
6008 should be able to do that.... they're well under $500.
(4,470 Views)
Not the 6008 for analog output. The ao is strictly software timed.
(4,468 Views)
Thanks for inputs. I've searched for a while and it seems that usb 6211 is still the best choice. I'll go with that. Thanks again.
(4,460 Views)
