Multifunction DAQ
MAX self-test not available for 9237
I had been successfully using a VB.NET program to control the ENET-9237 to read a load cell.
I have been using DAQmx 9.4 drivers.
Things were working fine for months....
Today when I tried to use it, I could not communicate with the device.  When I looked in MAX and ran the self-test I got an error indicating the device was not active.
I deleted the network device and added it again.  It adds just fine and I can see system status is up, but now the self-test button is greyed out.  I still cannot use my software to connect to the device.  So the ethenet part seems OK, but I cannot get access to the actual load cell module.
Does this indicate a hardware failure of the 9237 module?  Or is there still something in software I should try?
(2,918 Views)
Accepted by topic author CRB
Turns out it was a software problem.  I moved the hardware to a different computer and self-test worked fine.
I uninstalled and reinstalled the DAQmx v9.4 drivers on the computer with an issue.
Now everything works just as it should.
Not sure what went wrong with the original install...
(2,908 Views)
