02-20-2008 05:26 PM
02-21-2008 08:34 AM
02-21-2008 01:43 PM
vt92,
I was not able to duplicate the issue with your INI file. What you can do is clear your configuration manually in MAX and start fresh. This can be done by going through the following steps.
- Go to the start menu and click RUN
- Type “cmd” to open a command prompt
- Type “net stop mxssvr” to stop the MAX database service
- Go to C:\Documents and Settings\All Users\Application Data\National Instruments\MAX
- Rename the “Data” directory to “Data Backup”
- Now restart your computer and the next time MAX starts you should not have any tasks in your Data Neighborhood.
You may also need to reconfigure your hardware if your system does not find your DAQ device.
02-21-2008 03:36 PM
Thanks, Ryan. I'll give that a try.
