MIO 6070E doesn't work properly in PXI 1010
How do you do?
I'm trying to set a DAQ/condtol system with PXI 1010 chassis and LabVIEW. The hardware are PXI 1010, MIO 6070E, SCXI 1163R and 1102 to control relay and log temperature data. The system that consist of SCXI 1000 chassis with 1163R and 1102 via MIO 6062E on same LabVIEW code works properly. However, SCXI 1163R and 1102 that doesn't worked simulataneously in PXI 1010 chassis via MIO 6070E with muliplexed connection. If temperature can be get and relay doesn't work and vice versa if relay work. When I change the connection of 1163R from 6070E to DIO 6602 in MAX, both of function works simultaneously. But I think it's not all right.
Surely checked MAX and even pxi.ini file. And no suggestion from Korean expert
except it's wierd and time has passed meaninglessly. Beg your help.
(2,668 Views)
Greetings,
When you say that the 1102 and 1163R are unable to work simultaneously, what type of behavior are you experiencing? Do you receive an error? It sounds as if the jumpers on your 1163R are not set in the proper configuration for your current setup. You should check jumpers W2-W6 to make sure they are configured for your 6070E. Furthermore, do you have your 1102 connected to your 6070E and controlling the chassis?
Let me know.
Spencer S.
(2,668 Views)
Dear Mr. Spencer,
Thank you very much for your answer.
I'm trying to control electric devices with relay by 1163R and get temperature data from those devices by 1102 SCXI module. I checked the jumpers in 1163R for MIO and connected two modules to 6070E for PXI in MAX. However the operation is still impossible.
As you expected, I receive error code 10007 or 10004 when I stop the operation. Frankly I don't know what the error messages means because there was no error when I developed the LabVIEW code in 6030E and SCXI 1000 chassis.
Wishing your kind respose again,
Best Regards,
Sung Ki Kim
(2,668 Views)
