MTBF of the A/D multiplexer
Does anyone know what the Mean-Time-Between-Failure of the A/D multiplexer on the PCI-6225 is?  Is it the same for all M-series boards?
TIA
(3,084 Views)
It's no lower than that of any other component on the board. The switching is entirely solid state; you don't need to worry about wearing out the mux. Of course there are other reasons to switch less often, such as reducing settling errors.
All the M series boards use the same type of input multiplexer.
Chris
(3,078 Views)
