Measurement & Automation/ Instrument i/O error
I am trialing an evaluation version of labVIEW 8.5 and when I try and use the instrument I/O assistant, a pop up that says "Measurement and automation explorer or instrument assistant I/O is not installed properly. Please install these from the CD" is displayed...unfortunately I only have the evaluation version and no CD, can I download these from anywhere?
Once I get LabView working I plan to collect data using the Pico technology ADC-11 DAQ. Unfortunately, the driver for this device is not available on the NI website, do you know where I get the driver for this device?
Your help is much appreciated
Eskinder
(2,995 Views)
The Instrument I/O Assistant is part of NI-VISA. You can download the latest from http://joule.ni.com/nidu/cds/view/p/id/988/lang/en. At the top of the page you will see a link to 'Support'. This is the main link to any other NI hardware drivers you might need.
The pico web site says that the device ships with a CD and drivers for LabVIEW.
p.s. This board is not appropriate for questions about the I/O Assistant or devices from pico. This board is for DAQ devices from NI.
(2,986 Views)
