03-07-2012 04:06 AM
I am trying to setup a PXI 1050 chassis through a MXi4 optical fiber link. In MAX, the chassis first comes up as unidentified but then when I identify it as a PXI 1050 chassis the MXi4 link doesn't work - time out error message. What does this mean? Is there a solution?
Paul
03-08-2012 06:00 AM - edited 03-08-2012 06:08 AM
Hi there Paul,
Welcome to the NI Discussion Forums!
Just to catch up with you, have you been following this article?
In the 'Configuring PCI System in MAX', the point which sticks out to me is "Note: If you are using a remote controller, such as MXI-4 or 8360, to control your chassis, you should select External PC."
This will just make sure that the computer realises that's a part of the PXI Chassis via an MXI link, rather than trying to target as an internal one. We can then specify the type of chassis we're trying to connect to in the Chassis (Unidentified) section in the PXI System tree. If I were attempting to interface with a PXI-1052 chassis for example, I'd identify the chassis as the PXI-1052.
If this still doesn't work, would you be able to send me a printscreen of your current MAX configuration?
For timeout errors specifically:
I hope that this helps.
Kind Regards,
03-08-2012 06:18 AM
All sorted
03-08-2012 11:47 AM
What was the root cause?
