Making a numeric filter with LabView, using an analog input and an analog output
I'm using a 4474 and a serie M (with a SCC 2345 conditionning module), and LabView 8.0.
I'm acquiring continuously an analog signal with the 4474. After filtering the signal with LV, I want to write it on an analog output of the serie M (at the same rate and same number of samples).
I can't test it yet, because my hardware is not available.
Do you have any suggestion about this program ? Do you think it is possible ?
(3,302 Views)
Do you want to first acquire all your AI singals, filter it, save it to a file and then generate it on the M series card??
If it is so, Yes it is possible.
But if both are to be done in a cyclic order, acquire on DSA card>> Generate on M Series>> Acquire on DSA card and so on, I must admit that I have not tried this and so not sure how effectively it will work
(3,295 Views)
