voltage jumping
I have a 3v analog input connected at + 33, - 66. And its logging a voltage measurement every 30 secs. After about 15mins the voltage jumps to 10.6v and stays there. If i re-calibrate in the measurement and automation explorer its fine then jumps again in 15 mins. Its not my code because it happens even in the test panel in MAE. Anyone have any advise?
(3,073 Views)
Two queries Smiley Wink
which Hardware are you using??
What is the source of your 3V analog signal??
(3,067 Views)
