Making simultaneous frequency and analogue voltage measurements
Hi
I'm logging AI channels from two PCI-4472 boards, while measuring rpm from a 5000 pulse/rev encoder using a PCI-6602.  Currently I am using 2 DAQ Assistants, one for the DAQ boards and one for the counter/timer set to measure frequency (but I have also tried using the example VIs for frequency measurement as suggested in posts elsewhere).  Software is LabVIEW 8.6 / NI-DAQ 8.9.
The problem I'm having is matching up the real-time axes from the 2 datasets.  For the AI it is easy to control the number of samples and sample rate, but all I seem to be able to set is number of samples for the frequency measurement, and this returns a different length of data depending on the rotational speed (frequency).  I'd like to be able to acquire a fixed time (say 5s of frequency data) so it could be matched up with the AI from the DAQ boards.  If I try to acquire continuously there are of course buffer under-runs while one or the other DAQ assistant is waiting for the other to acquire all samples before another loop iteration.
Many thanks for any suggestions.
Aaron
(3,609 Views)
Dear AAron,
Is it possible that you can post your code here.
Fawad Nisar
National Instruments UK & Ireland
(3,583 Views)
Hi
Many thanks for the reply.
The code is very simple, 2 DAQ assistants: 1 logging 12 AI channels from 2xPCI4472, and 1 logging a single PCI6602 input fed with a 5000 pulse/rev speed encoder.
Here is my current version, I've been playing with quite a few options so it is a bit messy, if it is you want I can strip it down to the basics if it would be easier?
By default it logs 5s of DAQ data at 10kHz, and 50,000 samples of counter/timer (which equates to 20 revolutions at variable sample rate depending on shaft speed - I'd like to control sample rate and time like I can with the DAQs).
Appreciate the help, I'm new so I apologise if this seems a silly question...
Aaron
(3,579 Views)
first I want to say, I hope that everyone can read my english, because I don´t write often english 🙂
I´m trying to do something similar. I want to synchronize an AI with a CI (frequence measurement from an incremental encoder. I want to sample my AI with about 20 kHz and read about 2000 Samples with my DAQmx read VI. My problem is, that I want to have for every sample from my AI a sample of the frequency measurement. It dosn´t matter if it´s the same value that I read before. For example
AI     Frquency
1V   100Hz
2V   100Hz
3V   100Hz
4V   150Hz
5V   150Hz
6V   210Hz
5V   210Hz
4V   210Hz
so I have to read a frequency value at the same time when I sample an ai value. but i cannot set up an sample clock for frequency measurement. how can I sample the same amount of ai and ci?
if something isn´t clear I can write more information.
thankyou
johannes
(3,491 Views)
