Matlab Error: Analog Output underflow event - but I'm not using analog output!
AnotherDan,
I am glad that you were able to fix the issue! Since it was working in a test panel, it was most likely some syntax that was missing from your code that was changed when you rewrote your script. Thanks for the update, and I hope you are having a great holiday season!
Hannah
Applications Engineering
www.ni.com/support
Message 11 of 12
(971 Views)
Hey. Hey,
I have a similar problem. Were you able to identify the cause of the error?
Message 12 of 12
(253 Views)
