Max sampling rate on single channel differential for NI 622x DAQ
I know to know what is the max. sampling rate for the NI 622x DAQ.  This is single channel differential sampling.  On the Specs. it is 250KS/s but I know it is less then that.  SO I want to know how fast could it go?
(3,039 Views)
You should be able to sample at 250 Ksamples/sec for a single channel on this card.
Did you try it? and did it fail??
What was the error you got?
(3,031 Views)
Correct the maximum sampling rate is 250kS/s. This information can be found on the NI-622x Specifications.
Take a look at this discussion posting, Aggregate sampling rate and Multichannel Scanning Rate, for more clarification on sampling rate. The sampling rate is going to depending on the number of channels you will be using.
Please let us know if you have any additional questions or concerns.
Have a good one!
  Sandra T.
Applications Engineer | National Instruments
(3,021 Views)
