pci 6602 - using more than 2 counters for pulse generation
I am trying to control an experiment using pulse generation from a pci 6602 board. I was wondering if there is a way to generate pulses other than with the two general purpose counters (ND_COUNTER_0 and ND_COUNTER_1). I need to generate several pulses on different time bases. Any help would be greatly appreciated.
(4,196 Views)
Let me add on to this question, it seems there are other general purpose counters. I am using a NI BNC-2121 connection board to access my pci 6602 timing card. Is there access to these other counters through this connection? if not, how can i utilize these counters.
(4,192 Views)
There is only direct BNC access to counters 0 & 1 on the 2121, but the other counter inputs and outputs are accessible via spring terminals (PFI8-31). There are some user BNC connections as well that can be accessed with spring terminals as well.
I hope this helps!
gus....
(4,166 Views)
Hi ALL,
Yes, there is a way to generate  pulses other than  using counters.  you  can use  analog out - AO  square  wave generation. you can create finite pulses as well as continuous pulses. pls check your PCI card for any AO output availability. then sure u can achieve the pulses generation.
I have attached my example for you. check the channel, pulse rate(input), and desired frequency(output). let me know if u need any further help in this regard.
cheers.
Joseph (484-560-0943)
Budding  VI  expert!!!!!!
LEHIGH UNIVERSITY.
PA - 18015. USA.
(3,987 Views)
Good suggestion lehigh, but the 6602 does not have analog input or output. You can either use the counter to create a pulse train or you can create a digital pulse train on your own by using software timing, and toggling the digital line.
David L.
Systems Engineering
(3,974 Views)
Tanks David. I prefer harware timing than the software timing.
do you have any idea of how I can make my above example retriggerable. I want to retrigger the AO square wave finite pulse out. is there a way???
I KNOW we can retrigger finite pulses using counters but I want to know the same feasibility in the AO square wave output.
thanks
JOSEPH
budding vi expert!!!!
lehigh
(3,962 Views)
Lehigh,
Unfortunately, the hardware does not support this without using counters. Please see KB: 2IL8JEXA.
David L.
Systems Engineering
(3,954 Views)
