Measure amplitude of nanoseconde, short pulse.
I am looking for a simple solution "cheap" to replace our 500Mhz scope we use to measure a short pulse of a few nanoseconds (~6ns with 80% amplitude decay, maybe 20ns total) in our laser chain at a frequency of 100Hz. The pulse is not square or TTL, it s a signal decade with fast rising sloop and slow discharge, more like an rounded exponential ramp. Amplitude is around 1.5V peak.
I don t need an absolute value of the voltage or the waveform, I am more interested in the maximum amplitude jitter between shot to shot “pulse to pulse” at 100Hz. I was thinking about using some M series board that I would trigger it s analog input with an delayed TTL that corresponds to the diode maximum (as measured by the scope) and then output a single point 100 times per second and compare them. Problem is, I assume, that there isn’t a card that has a settling time of a few nanoseconds, or a sufficient  trigger response delay, am I right?
I also heard about sample and hold signal conditioners put I am confused  on which one would suite my application without over killing and over billing, are they fast enough?
Thanks for any help
Lukasz
(3,121 Views)
Hi Lukasz,
It is my understanding that you wish to take one sample every trigger edge, and the sample must capture the largest amplitude. such as shown in the picture below.
If I am correct in my understanding I do not believe that an M-series card will be capable of capturing the data that you wish to. An M-series card can capture, at best, samples that are 357 ns apart. So any jitter in either the sample clock or signal would cause you to miss your entire signal. I recommend a scope which has a much higher sampling rate. For example the PCI-5152 is capable of 2Gs/s which equates to .5ns between samples.  I believe that the best solution for you application would be to use the PCI-5152 and an advance trigger, The Advance trigger initiates the acquisition of the additional records in a multirecord acquisition.  You can define the number of samples that you want in your record, and then the advance trigger will allow you to capture a record on each trigger pulse. This will allow you to capture the section of interest and use post processing to compare the highest points of each record. I hope this helps!!
Message Edited by jaced on 11-02-2007 03:40 PM
JaceD
Signal Sources Product Support Engineer
(3,083 Views)
