Measurement Computing USB-1208FS and USB-6008 and 6009
HI,
Is the Measurement Computing USB-1208FS compatible with the NI family of USB boxes?  USB-6008, USB-6009, Etc.  If not, can I get the DAQ VI's easily?  On initial appearance, they look very simular.
(5,716 Views)
Accepted by zener
No, they are not compatible at all at the driver level. If you need a driver from Measurement Computing, you need to ask Measurement Computing.
(5,708 Views)
can someone help me to find some project MCCDAQ with USB1208FS in LabView 8.0 professional
 versions.taxn before
(5,558 Views)
Hi ,
Check out the following discussion forum. It has all the links you need to use the MCC DAQ in LabVIEW.
Faris A
Bueller
(5,533 Views)
can i make the ecg heart signal detect with labview in this daq (1208FS)? if it's can can someone give the sample please...
tanx before
(5,286 Views)
Hey Marp84,
Once you acquire the signal, LabVIEW will allow you to perform all sorts of signal conditioning on the signal.
Please check the following online tutorial for ECG measurement.
Best Regards,
Faris A
Bueller
(5,261 Views)
