Microphone to DAQ
Hello everybody
I need your help to conect a microphone in a 9231 DAQ Module. The model of the microphone is GRAS 40PP.
(1,388 Views)
Hi Gerardo,
What difficulties are you encountering specifically? You can directly connect this microphone to a NI 9231 with a 10-32 coax.-to- BNC cable.
Alex
Hardware Engineer
(1,367 Views)
Hi Alex
The main problem is related to the acquisition and configuration of the communication channel. I don't now how I could do it. I have been searching some examples in differents websittes, and now, I have this.
I am using a microphone GRASS 40PP, which have this specifications:
I never used a DAQ, any information or example might be of great help.
Sorry for my bad english u.u
(1,361 Views)
You've to use AI TEDS Microphone as the task type instead of the AI Microphone which allows you to configure the IEPE current and allows DAQmx to fetch calibration data from the Mic.
To quickly test things out, you can install the DSA soft panel - https://www.ni.com/en-us/support/downloads/drivers/download.dsa-soft-front-panels.html#376770
In terms of example code, please use this one
And configure to use Sound pressure with appropriate settings for the highlighted controls,
Santhosh
Soliton Technologies
(1,341 Views)
