PXIe-6251 Showing Negative Current Device Temperature, all open-circuit voltages at -0.0012V
Just bought a new-to-me PXIe-6251 and am trying to troubleshoot these issues to determine if I have a dead board or not.
Self-test passes.
Self-Calibrate fails (Status Code: -200545), tried un-plugging and re-plugging, restarting, resetting, etc.
Current Device Temperature: -49.9°C
I have successfully self-calibrated my other NI PXI boards with no issues.
All voltages show "-0.0012V" flat, no ripple (which seems odd since it's open with no connector attached).
What can/should I do to try and resolve this issue?
Other setup information:
- New Dell Lattitude Laptop with Thunderbolt 4 ports
- New PXIe-1090 Chassis
- New Thunderbolt 3 (20gbps) cable
- New Power Cable
- PXI-6255 connected, fully functional
- PXIe-6251 connected, (see above for problems)
- Latest versions of all software (NI MAX, etc) latest windows updates, etc. etc.
(1,087 Views)
High chance that the board is damaged and requires repair. If the firmware is functioning correctly, at least the temperature should be read back correctly.
Santhosh
Soliton Technologies
(1,068 Views)
