Modify programmaticaly a physical channel in a task
I'm looking for a way to modify the physical channel of a task.
I already tried this but got an error...
Does anybody has an idea how to implement this correctly?
The goal is to have a preconfigured task with many channels where I can change some physical channels if needed.
Thanks for any help.
Yves
(3,719 Views)
Instead of PhysicalChanName property, did you try using Channels property?
(3,664 Views)
Not yet. I'll try it tomorrow and give feedback.
Thanks for the idea.
Yves
(3,650 Views)
I just tried your approach.
Did you meant something like this?
If yes, then it didn't work.
(3,635 Views)
This is not an authoritative answer, but I *suspect* it to be true:
A defined task is inextricably bound up with the physical channels it was configured to contain.  To change the physical channels involved in a task would require clearing the original task and configuring a new one with the new set of physical channels.
At least, I *think* so.
-Kevin P
(3,624 Views)
Accepted by Yves
Well, to be honest too, I talked to NI support.
And after some checks they admitted that this can't be done programmaticaly. This function seems to be read-only even if it looks like it's possible.
I'd say this is a bug! Otherwise it should be documented clearly and obviously it is not.
And come on, why shouldn't it be allowed.
But anyway. For my this case is closed and I resignate to build the daqmx-task everytime I need to change something.
Yves
(3,606 Views)
-Kevin P
Just to chime in, and not an authoritative answer. I have added channels to an existing task without clearing it, etc. However, if I wanted to remove channels from an existing task, then I had to clear, configure a new one, etc.
mcduff
(3,569 Views)
