Multifunction DAQ
Module names per cDAQ chassis?
Hi all,
is there a way to get module names cDAQ-chassis based?
I'm trying to check if two (or more) identical chassis with different modules are connected to my PC.
Example:
Module 1: cDAQ-9174 with Modules "A", "B", "C", emptySlot, in just that order
Module 2: cDAQ-9174 with Modules "D", "E", "emptySlot", "emptySlot"
Problem:
The "ActiveDev" property node then delivers the ProductType output array of [cDAQ-9174, cDAQ-9174, A, B, C, D, E, ...further devices on the system]
I can't see which of the modules is plugged into which chassis.
Any help is appreciated!
Thanks in advance
Achim
(4,713 Views)
Accepted by A-T-R
Hi Achim,
Please see the attachment or the screenshot for the requested functionality.
The example is a modified version of this example:
Community: Get cDAQ Module Types in LabVIEW - National Instruments
https://decibel.ni.com/content/docs/DOC-15978
If you meant something different, just write me back.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(4,688 Views)
Hi Christoph,
thanks for the code! I found a slightly different, but by far not so smart, solution...I'm checking the ActiveDev.ProductCategory, and if a "14658" shows up, I then check the ActiveDev.Chassis.ModuleDevNames, ProductType(s) for the right chassis (only one should be connected), and the right modules in this chassis.
Elsewise, I produce errors.
Best regards
A-T-R
(4,680 Views)
