Monitor AO channel with Traditional DAQ
I would like to monitor one of the AO channels using Traditional DAQ. With DAQmx, one can specify an AO channel to be read (e.g. Dev1/_ao0_vs_aognd). Can one do the same thing using Traditional DAQ without physically wiring an output channel to an input channel?
Thanks, Peg
PS - I posted this under LabView but thought maybe it should be posted here instead.
(2,809 Views)
Please refer to the answer on this post.
aNItaB
(2,789 Views)
