How do you change the target directory for NI-DAQ 6.9.3?
I am attempting to install NI-DAQ 6.9.3 onto a new laptop.  I attempted to change the target directory, but the installer will not allow me to change it.  Is it possible to change the directory?
(3,055 Views)
Accepted by topic author jds123
When you say that the installer will not let you change the target directory, do you recieve an error?  I believe it is possible to change this target directory by selecting feature in the feature tree and then manually changing the target directory toward the bottom of the installer.  When this is done, a pop up will occur that says a new folder will be created to save the files to.
Jordan F
(3,039 Views)
