Question about EPM Tutorial from NI.com
Hi
I Downloaded the Electrical Power Measurement Tutorial from NI.com the other day.  Unfortunatly the VI's are all written in Labview 8.6.
I only have 7.1 or access to a version 8.0.  Is it possible to get this tutorial for version 7.1 or 8.0?
I am interested in measuring \ calculation Power factor and Power by aquiring simultaniously Voltage and Current Waveforms.
If anyone can help with the EPM tutorial or any other VI's i'd be very appreciative..  PS I'm planing to use a PCI-6115
(4,337 Views)
Hi Barry,
Could you please post a link to the webpage you mentioned, and I will then investigate further, and inform you of any options which are available.
Steve
(4,312 Views)
Hi Steve
Below are the links for the Electrical Power Measurment Tutorial.
http://zone.ni.com/devzone/cda/tut/p/id/8198
https://lumen.ni.com/nicif/us/codelvelectpwr/content.xhtml
Thanks for the help
Regards Barry
(4,306 Views)
Hi Barry,
Unfortunately there was no version of the tutorial made in LabVIEW 8.0 or 7.1
I tried to convert the project back from 8.6 to 8.0 but there are some functions used in the code which aren't available in LabVIEW 8.0.
Steve
(4,291 Views)
Thanks anyway Steve.
I Started to compile my own code i'll try to post it later and you can see if you think it will work or not.  lol
Regards Barry
(4,288 Views)
Hi Steve
Attached is the code i've written so far.
Regards
Barry
(4,279 Views)
