 davey31415
			davey31415
			01-14-2008 10:18 PM
 Chris_K_
			Chris_K_
		01-16-2008
		08:51 AM
 - last edited on
		05-02-2024
		08:56 AM
 by
		 Content Cleaner
			Content Cleaner
Hello Davey31415
Depending on the exact requirements for the measurement you want to make, number of inputs you require, budget, and many other factors will determine the most effective DAQ system that suits your needs. Instead of conversing over the forums, I would suggest contacting one of our technical representatives.
We have a team of technical representatives who specialize in configuring full systems.
National Instruments doesn’t make any wireless DAQ devices, however please have a look at the following link to another forum post. It explains a remote cRIO application was created using a WLAN module from a third party supplier.
https://forums.ni.com/t5/LabVIEW/Wireless-Compact-RIO-Data-Transfer/m-p/537629?requireLogin=False
If you do want to go with the WLAN cRIO option, and depending on other measurement needs, the NI 9205 would be a good choice. It can be used for low voltage thermocouple readings, and voltage signal readings. If you want a thermocouple specific device in the cDAQ form factor the NI 9211 has better bit resolution for more accurate readings. The cRIO can be configured with an imbedded controller so a computer is not needed with the DAQ system. For more information about the modules and the cRIO system please follow the following links
NI 9205 https://www.ni.com/en-us/shop/model/ni-9205.html
NI 9211 https://www.ni.com/en-us/shop/model/ni-9211.html
CompactRIO Advisor http://ohm.ni.com/advisors/crio
As for the power supply and switch, we currently only have one power supply, and it is PXI Based, and our switched are only PXI or SCXI, so you might want to look at a PXI based option as well.
PXI Advisor http://ohm.ni.com/advisors/pxi
Power Supplier https://www.ni.com/en-us/shop/category/power-supplies-and-loads.html
Switches https://www.ni.com/en-us/shop/category/switches.html
National Instruments also has a touch panel that can be used for your interface, for both control of the test application and monitoring.
Again there are so many components in your proposed system, and I have only given you a general setup. It would be extremely beneficial to contact one of our technical representatives for further help. They will be able to fine tune the selections I have pointed out. Also if you have specific questions about any given component they will be able to better direct you to the proper departments and you will obtain an overall faster solution.
Have a great day
Chris_K_
01-16-2008 12:25 PM
Chris_K_,
Thank you for the information. I will definitely speak with a rep from NI about these options.
David
01-16-2008 10:38 PM
