06-10-2020 10:53 PM
I want to attach four different sensors e.g photoelectric sensor, laser sensor, fiber optic sensor, and ultrasonic sensor with one DAQ and get the data of each sensor. Please suggest me which NI DAQ will be suitable to perform this task as well as need code.
06-12-2020
12:22 PM
- last edited on
01-11-2024
10:52 PM
by
migration-bot
I recommend checking ni.com/daq to find all the current solutions and finding one that complies with your sensors' specifications.
If you plan to use a single card, I expect you to need external circuitry to have high fidelity measurements (depending on the return values each sensor provides).
Else, you can consider a CompactDAQ with the modules that are best suited for each type of measurement and fit your desired specifications.
All the best,
06-13-2020 02:05 PM
A couple of things to consider:
mcduff
PS If you need somebody to write code for your application there is a job board here, otherwise the examples in the example finder are a good place to start.
