Multifunction Synch AO AI Same Clock - restart AO? From different postion in the buffer?
Yes, it can definitely be set to something smaller (I think the minimum is two ticks of the 20 MHz timebase).  I put it in there so that if needed, you could delay from the sample clock a bit to let your AO signal settle before you sampled AI.  If that's not a concern for you, you can remove it all together, if it is, you can experiment and find the value which works best for you.
Dan
Message 31 of 31
(697 Views)
