Multiple 9221/9162 USB DAQ Conflict
I'm using LabVIEW 8.6.1 and NI-DAQ  8.8 on Windows XP. I'm trying to set up two NI 9221/9162 usb controlled DAQs to work at the same on the same computer. Each unit works individually, but If I plug one in after another the first one that was plugged in stops responding and I get the below error on a self test in MAX.
When I attempt to use the unresponsive DAQ with the softpanel in MAX I get the following error.
However, if I plug both usb cables into the computer at the exact same time I don't get the device conflict error. Unfortunately this work around is not a desirable solution for the environment this test will be deployed in. This problem persists on different PCs. Is there a better solution for this problem that will allow both devices to respond regardless of the timing in the plugging in the usb cables?
Thanks you.
(2,836 Views)
Thank you for using NI forums.  Are you plugging these devices in through a USB hub or directly to the USB ports on the comp?  The reason I'm asking is because this behavior is usually the result of using a hub for your USB devices.
(2,820 Views)
