My Reg level program needs deviceID for NI 6025 E card as per PCI local BUS spec
Hello Amit,
Many of the features I mentioned above require both Windows 9x (minimum) and newer versions of drivers than are available for your target system. I would recommend that you visit our "Data Acquisition Register-Level Programming Resources" webpage and download the "PCI E Series Register-Level Programming Manual", the "DAQ-STC Technical Ref Manual", and the PCI E-Series examples (PCI-ESer.zip) The examples include code that will scan for your card via the PCI BIOS and configure its MITE chip for operation (VERY helpful!). I wish you well on your project.
Sincerely,
Jeremiah Cox
Staff Product Support Engineer -- Platform Services
-- http://www.ni.com
Message 11 of 13
(719 Views)
Hi jeremiah,
Greetings.I was going through the PCI E Series Reg Level programming Manual. I see several references to a "Companion Disk" which is said to contain more example codes.
Where can I get this disk ?
abhijay
Message 12 of 13
(902 Views)
Hello again abhijay,
I believe they are referencing the examples that you can download from ftp://ftp.ni.com/support/daq/pc/reg-level/dos/pci-eser.zip .
Jeremiah Cox
Message 13 of 13
(902 Views)
