My sestem not detects NIDAQ 6008
Dear Sir,
I m tring to use DAQ 6008, It is not detecting on system,
I opened Measuerement and automation explorer, clicked on "device and interfaces", getting an error message saying that" The MAX database exited abnormally, Visit ni.com/info and enter the info code MAX terminatedServicesError if the problem persists go to ni.com now"
i also tried the solution given on web, but still not working.
(3,067 Views)
Hi Ibirru,
It seems that a corruption occurred in your MAX database. This can be due to a number of reasons, most commonly a system crash.
A possible solution to your problem is to remove your corrupted MAX database. Please be warned that this will remove all custom configuration data you have saved in MAX.
The process for removing the corrupt database can be found here. Alternatively, you can use this example VI which will delete the database for you.
Please let me know if this works.
Thank you,
Eden S
National Instruments UK & Ireland
(3,065 Views)
