no input signal (4-20 mA expected) on NI 9208
Hi everyone.
I encounter difficulties getting analog input signal (4-20 mA) using NI 9208 mounted on cDAQ 9188.
Here is the configuration :
- pressure transmitter 2-wire connected (IN: +24V) (OUT: NI 9208 AI6 pin) (power supply from external source sharing 0V and ground with NI 9208 COM pin)
- NI 9208 : Vsup = +24V (pin 19 & 37) ; COM = 0V = GND (pin 9 ; 10 ; 28 ; 29) ; AI6 = OUT pin of transmitter
[Attached, a drawing of the cabling]
- Driver NI DAQmx 9.3
- Labview 10
- Windows 7
Using a DAQ assistant configured to acquire analog current signal, the value I get on screen is fluctuating between 0.001 and 0.1 mA.
I inserted a current measuring device in line between the OUT pin of the transmitter and the AI6 pin of the 9208, here I actually get the 4-20 mA signal.
As complementary information, I measure 28V between Vsup and COM ; 0.3V between AI6 and COM ; and 27.7V between Vsup and AI6.
To make the topic as clear as possible I might add that firstly, each input channel was connected to a transmitter, each giving at screen the same value of ~0.01 mA (amperemeter not tested yet on each AI => next step of my investigation, actually performed). Then I tried to identify the problem connecting only one transmitter (AI6). Result is still the same.
As the NI 9208 once functionned well some month ago, I expect the problem to come from one transmitter which may have been wrongly connected. (I'm actually cheking all connections).
My question would be : Is the 9208 behaving typically such a damaged device (ADC?) ? Or maybe this appears like there is something I missunderstand ?
Any piece of advice would be greatly welcome.
By the way, please forgive my aproximous english.
Thanks for your consideration.
Adrien QUEUCHE
(4,374 Views)
Accepted by topic author adrien.queuche
Well, it was my mistake. I was reading mA where I should have been reading A....
To any administrator : the topic may be deleted, i guess. Unless i deserve to be ashamed for eternity...
Thanks.
Adrien QUEUCHE
(4,362 Views)
