NB-AO-6 jumpers and programming hints
Hi all
I am resetting a Mac ci System with NB-AO-6 , I found this pinout NB-AO-6.pdf info on NI site.
But I also need the jumpers selection and some programming hints for this board.
A user's manual would be nice too.
Many thanks
Rollo
(3,113 Views)
Hi Rollo,
the only document I found is this. It is a copy of a few pages of an old catalogue.
Klaus
(3,097 Views)
Hi Klaus
Thanks, is the same file whose name I provided...
on the other hand, I've found another file in the NI site, AT-AO-6/10 User Manual.
It is for IBM PC instead of NB  MAC but it presents W1...Wx jumpers which I hope might have
the same function. I 'll let you know if my assumption is true...
Rollo
(3,079 Views)
Hi Rollo,
a colleague of mine was able to track down a print copy of this manual, converted to .pdf. I've attached it here.
Thanks-
Klaus Dinnes
NI Application Engineer
(3,030 Views)
