NI 6008 DAQ - Labview Example Code 4*AI, 2*DI, 2*DO - DAQMX 8.0
Hy,
I'll start programming with Labview 8 and I searched the ni.com site für example code, using 6008 with (at the same time) 4 Analog Inputs (floating or single ended), 2 Digital Inputs, 2 Digital Outputs, ....
All the examples (I found) have only one separate channel but not all the different kinds of channels in one example!
I'll use DAQmx 8.0 and Labview 8.0 on WINXP - SP2!
Thank's for help!!!!!!!!!!!!
(3,326 Views)
The most simple solution is the following:
you can copy the example code, to build an all in one but you can't find an example with all channel.
In the LabView courses from National Instruments there is also no example with all channels you learn to use the different channels separately, but never all together...
Best Regards
Matthieu Papaux
Application Engineer
NI Germany
(3,294 Views)
