08-25-2006 02:02 AM
08-28-2006 06:03 AM
The most simple solution is the following:
you can copy the example code, to build an all in one but you can't find an example
with all channel.
In the LabView courses from National Instruments there is also no example with
all channels you learn to use the different channels separately, but never all
together...
Best Regards
Matthieu Papaux
Application Engineer
NI Germany
