NI-6008 OEM Only loads the Firmware Loader and not main drivers.
ok, thanks, that explains it. I started with the Base 2.00 for developing the application and then I installed 8.3 on top of it. I will do a clean install with only 8.3 another machine. Actually I called NI support but I don't think they understood the problem, I will email them instead with a reference to you.
Message 11 of 13
(1,333 Views)
When i plug USB-6008, it says "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing". But i already installed NI-DAQmx. version-8.3.
It is still not working. So what should i do?
Message 12 of 13
(1,064 Views)
I solved this problem for myself a while ago my problem was the discs that were shipped with my NI06008 were out dated and had to go online and download the newest NI Measurement and Automation software and the Base drivers.  I'm not sure what the other problems people are describing are caused by. If windows is saying it can't load the driver it could be your unit is defective or did you plug it in before installing everything?  Also did you try manualy selecting the driver for the device instead of letting windows do it automaticaly?
Message Edited by Seth Martin on 02-18-2008 08:02 AM
Message 13 of 13
(1,058 Views)
