NI-6008 selecting voltage range from Matlab .m file
Hi, I need to select a voltage range such as -1V to +1V from .m file in MATLAB to acquire data from NI-6008 DAQ.
I appreciate if some one send me an example code.
The system is working fine and I can successfully control sampling rate but not the Voltage range.
Regards
Message 1 of 8
(6,146 Views)
Please see this discussion forum post related to your input task:
http://forums.ni.com/t5/Multifunction-DAQ/ni-daq-6008-with-matlab/td-p/2515242
Message 2 of 8
(6,113 Views)
Thanks. I will check it.
Best regards.
Message 3 of 8
(6,099 Views)
Hi Karl, it seems that non of the provided answers in the discussion solve my problem. Therefore my question is still waiting for a valid answer.
Many thanks for your help
Message 4 of 8
(6,098 Views)
s = daq.createSession('ni')
ch = s.addAnalogInputChannel('dev1', 0, 'voltage')
ch.Range = [-1 1]
Alternatively,
s.Channels(1).Range = [-1 1]
Wael Hemdan
MathWorks
Message 5 of 8
(6,093 Views)
ch.Range = [-1 1]
Alternatively,
Wael Hemdan
MathWorks
Thanks Wael.
I will try the second alternative as the first one did not work.
Best regards to you.
Message 6 of 8
(6,089 Views)
Accepted by Mus90
Hi
Both alternatives are equivalent, the 2nd alternative is how to get to a channel if you had not saved it to a variable when you created it.
When you say it did not work, did you get an error message?
I just tried it on my machine with an NI USB-6008 with 4 channels, and range set to [-1 1] on one of those channels:
s =
Data acquisition session using National Instruments hardware:
   Will run for 1 second (1000 scans) at 1000 scans/second.
   No channels have been added.
>> s.addAnalogInputChannel('dev2', 0:3, 'voltage')
ans =
   Number of channels: 4
      index Type Device Channel MeasurementType      Range       Name
      1     ai   Dev2   ai0     Voltage (Diff)  -20 to +20 Volts
      2     ai   Dev2   ai1     Voltage (Diff)  -20 to +20 Volts
      3     ai   Dev2   ai2     Voltage (Diff)  -20 to +20 Volts
      4     ai   Dev2   ai3     Voltage (Diff)  -20 to +20 Volts
>> s.Channels(2).Range = [-1 1]
s =
      2     ai   Dev2   ai1     Voltage (Diff)  -1.0 to +1.0 Volts
Properties, Methods, Events
>> s.inputSingleScan
ans =
   -0.0034    0.0008    0.0012    0.0059
Wael Hemdan
MathWorks
Message 7 of 8
(6,084 Views)
@whemdan wrote:
Hi
s =
ans =
s =
>> s.inputSingleScan
ans =
Wael Hemdan
MathWorks
Great.
Thanks a lot Wael.
It is now perfectly working.
Best regards
Message 8 of 8
(6,071 Views)
