NI-6509 shortcut
Hi all,
I use a NI-6509 (96 I / O) and SCB-100 case.
By manipulating I made by error a c/c between an I/O output configured to +5V and I/O input configured to ground.
Since then, nothing.
Using Measurement & Automation tool, I tested the ports: Autotest = OK, nothing on the outputs (I put leds).
I thought the card was protected against shortcuts.
Someone there an answer?
Thank you in advance
(2,902 Views)
Could you try the DAQ Diagnostic Utility?
http://joule.ni.com/nidu/cds/view/p/id/2244/lang/fr
It will help us to detect the issue.
Regards
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
GEMESIS.EU
(2,873 Views)
