NI-6537: each Individual port can be programmed either for Read/Write Is right?
I have to run the Input stimulus from NI-6537 to asimple CRC design on  FPGA.
If i program Dev1/line0:11 for write  and Dev1/line12:19 for read , I got this error.
Error in DAQ writing format to NI-6537->Measurements: Specified operation cannot be performed while the task is running.
Task Name: DaqmxTask
So for my understanding that you can program the port as for Read /Write not both , Is it so?
Is there a way that I can write to some pin s and read on some pins on particular port?
attached is the program
rename it CRC_1MHz.txt CRC_1MHz.hws
(2,904 Views)
Hi Molugu,
Yes, you can program the lines of the port to read or write. With NI-DAQmx you can configure each physical line of the 6537 individually. As a first look, I don’t see what could be wrong in your code. I was not able to run the application, so I would like to confirm what type of application is this, MFC, Win32? Molugu, there are some C examples about Synchronization that could be helpful in this case, this knowledge base explains where to find them. I hope this is helpful,
Ana P
(2,878 Views)
