Multifunction DAQ
NI-9191 and Crio-9075
Hello..
I would like to know if I can see my NI-9191 Wireless chassis through my CRio-9075?
I have my CRio-9075 connected to a wireless access point and the NI-9191 to this acces point too...
The Idea is to read my NI-9234 input module through my NI-9191 located at 20ft away.. and on the other site I have my CRio with another NI=9234 module to read another machine channels.
Note: I can not use ethernet wires across the trafic lines and this is why I would like to use the NI-9191 and the CRio... I will need to run my application on the CRio and to publish my data with network variables to a Surface Tablet.
IS this possible?
Thank you
Checo
(5,216 Views)
Accepted by Checo
Hi Checo,
That wouldn’t be a supported configuration. The NI-9191 requires the DAQmx driver, which is something you cannot install on a cRIO.
Have you looked into the next HW options?
NI 9795:
https://www.ni.com/en-us/support/model.ni-9795.html
NI WSN-3202:
https://www.ni.com/en-us/support/model.wsn-3202.html
AGJ
NI
(5,197 Views)
Hello AGJ_CR..
Yes.. I will move and use the WSN radios for this application..
Thank you for your help ! ...have a good one..
Checo
(5,184 Views)
