NI 9203 accuracy problem
9203 module does not have any filtering built in.  Noise will be an issue.  I just went through a similar problem with noise.  Since I was dealing with a somewhat static signal, I was able to acquire 20 samples, discard the two highest and two lowest readings and then average the remaining 16 samples.
Message 21 of 21
(974 Views)
