NI 9215 Input Range
Quick question.  When I select the 0 to 10 VDC input range on the 'Create Virtual Channel' Daqmx vi while using a NI 9215 have I effectively made my 16 bit voltage input into an 8 bit voltage input or does the NI 9215 front end adjust itself to take advantage of the entire range of the ADC?  Thanks.
Kyle
(3,530 Views)
Accepted by kyle.hall
The NI 9215 only has one possible range in hardware, ±10V nominal (it's acutally typically about ±10.4V, minimum of ±10.2V, max of ±10.6V).  If you define a smaller range, as in your example of 0V-10V, the NI-DAQmx driver will choose the smallest range that the device is capable of and uses that range in hardware.  Since there is only one range (±10V) that is the range that the hardware will use.
For devices capable of multiple ranges, such as X Series or the NI 9205, if you were to define a range of 0V-4V, the driver would determine that the smallest range that contains the user specified range is ±5V and set the ADC range accordingly.  If you were to choose 0-6V or ±6V etc, the driver would find that the smallest range possible is ±10V and use that range instead.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(3,528 Views)
