NI 9219 bandwidth
What is the bandwidth of the analog filter preceding the ADC?
Message 1 of 9
(4,700 Views)
Hi stevem80,
What is your overall application?
Joel I.
Message 2 of 9
(4,666 Views)
Measuring voltage and temperature (thermocouples and RTDs)
Message 3 of 9
(4,661 Views)
Ok, and just out of curiousity, which part of your application would obtaining the filter bandwidth help with?
Joel I.
Message 4 of 9
(4,658 Views)
I would like to know the frequency response, i.e., the -3dB point.
Message 5 of 9
(4,647 Views)
stevem80,
Generally we keep information such information internal.
Joel I.
Message 6 of 9
(4,644 Views)
Maybe my question wasn't phrased correctly.  What is the signal bandwidth of the NI 9219?
Message 7 of 9
(4,642 Views)
Hi stevem80,
The signal bandwidth is 0-100Hz, and the analog filter's bandwidth is well above this range and should not effect any measurements you obtain.
Joel I.
Message 8 of 9
(4,607 Views)
Accepted by stevem80
Thank you very much.
Message 9 of 9
(4,605 Views)
