NI 9234 Ethernet Connectivity
I am trying to find out if I can NI 9234 to acquire vibration data from 2 triaxial accelerometers.  The issue is that the equipment that I am trying to test is almost 30 feet away from the acquisition PC.  Therefore, I cannot use the NI USB 9234.  Does anyone know I can acquire data through Ethernet?  Ethernet cables can run longer, which is ideal for my application.  Does NI 9234 come with an ethernet port?  Any advice is much appreciated.
(3,524 Views)
It sounds like you want an ENET-9234 or WLS-9234.  They both use the same NI 9234 module but have Ethernet and wireless support.
(3,515 Views)
Test
(2,919 Views)
