syncronization of analog output with counter pulse
Hi
i am working on Ni USB 6353 X series board.i want to route AO start trigger to output terminal (@ any line) which would be used for counter single pulse trigger for Sync with analog output generation. in x series user manual this is mention ,but how could i use?
Harshida.
(3,026 Views)
Here's an illustration of how to do it with LabVIEW.   There are similar functions available in the text API's.
-Kevin P
(2,990 Views)
Hello!
I have tried according your suggestion and it is worked fine.
Thank you so much for help.
Harshida
(2,961 Views)
