NI 9234 software trigger
I am a beginner in Labview and DAQ as well. I plan to buy NI 9234 and 1 slot cDAQ NI 9171 in order to work with 4 accelerometers. I know that I cannot use hardware trigger in this type of DAQ. Could anyone can help me whether or not the DAQ can be defined software trigger ?
For my case, I need DAQ will collect the data when sample value larger than 1g and stop to collect when sample value smaller than 1g.
Thanks a lot.
Tom
(3,756 Views)
Hi Tom,
You can use a software trigger with the NI 9234. This forum:
https://forums.ni.com/t5/Measurement-Studio-for-VC/am-looking-for-any-example-vi-s-for-impact-modal-...
includes an example of software triggering with the NI 9234.
Also, since you are new to DAQ and LabVIEW, here is a document which discusses 10 NI-DAQmx functions. There is also a section on triggering:
https://www.ni.com/en/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-handl...
Sunaina K.
Product Marketing Manager for CompactRIO & TSN
Making the intangible, tangible
(3,745 Views)
