DAQmx Analog and Digital acquisition to the same TDMS log time using DAQmx Configure Logging
I need acquire analog and digital(port level) signals using the same device(USB-6343) at the same time(same start and end trigger) but different rates, Analog @ 20kHz and Digital @ 1MHz. I would prefer to same them to the same TDMS file, is this possible and ,is so, how do I set this up?
Ryan Podsim, CLA
(2,968 Views)
From what I have looked at so far it should be possible.
Take a look at the example under Hardware Input and Output -> DAQmx -> Synchronization -> Multi-Function -> Multi-Function-Synch AI-AI-Ext Dig Trigger.vi
It demonstrates how to simultaneously trigger two DAQmx tasks from the same source.
As for the TDMS part look through the TDMS examples found in Fundamentals -> File Input and Output.
Are these resources helpful?
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(2,945 Views)
