custom scale per physical channel
Need help on configuring 5 physical channels each using different custom scale(linear) such that the user will have access to each 'm' and 'b'.
An example closest to this would be:
http://sine.ni.com/devzone/cda/epd/p/id/1668
8_0_programmatic_saving.llb
see "Create and Save Task, Channel, & Scale.vi"
However, this example has only one custom linear scale. I need a custom scale for each physical channel (5) and will eventually be routed to one task.
thanks,
jose
(2,882 Views)
Nevermind, I think I found my answer.
http://sine.ni.com/devzone/cda/epd/p/id/896
(2,881 Views)
