‎11-13-2007 09:16 AM
‎11-13-2007 09:49 AM
‎11-13-2007 10:17 AM
‎11-13-2007 10:47 AM
‎11-14-2007 11:20 AM
‎05-13-2010 08:25 AM
What about the maximum distance from NI 9237 and transducer? I have to measure deformation by a 350 Ohm full-bridge with available 6 wires + shield cable.
regards / s.q.
‎05-14-2010 05:16 PM
Hi qNorman,
I am not sure that I can give you a concrete answer on the maximum distance of the strain gauge from your module. However, I can recommend half or full-bridge configuration that way you can use remote sense on the 9237 module. This will allow for you to account for lead resistance in your connection, and the voltage drop that is encountered in the wire length. Excitation voltage degredation is the main enemy in the setup, which remote sense accounts for.
Best,
